WSJK800
Everything posted by WSJK800
  1. Update: I went to open area yesterday and took Steve's advice. All antennas have a 3+ SWR using the trucked mounted NMO. I connected the magnet base with the unity gain antenna that came with the radio and the SWR was 1.1 and the Ghost had 1.124 SWR. The only thing it could be now is the through hole NMO/cable. I'm going to put a new PL-259 on and if that doesn't work then I'll have to drop the headliner again and install a new mount/cable.
  2. Hello, I recently installed my new GMRS radio and getting high 3 to 3+ SWR readings using the Midland Ghost and the Midland 32" whip antenna in an open area. When I connect the magnet antenna that came with the radio, I have a 1.3 SWR. The NMO mount is 3/8 through hole and mounted in the center of my Tacoma roof. The radio is powered direct to battery both positive and negative. The base of the NMO mount has ground continuity with the outside threads of the PL-259 female on the radio. The mount has good continuity with the shield/outside and center conductor on the PL-259 at the end of the cable with no shorts. I do get a short between shield and center conductor when I screw on either antenna. I'm thinking maybe the coax was compromised somehow during installation and I'm facing pulling the headliner down again and installing a new mount. I'm in San Diego if anyone works on these things and would be happy to pay a professional to get it right. Any advice would be appreciated. Here's my setup: Arcadian MABVT8U: 3/8 Thru-Hole NMO Mount with 17 Ft. RG-58/U Cable MicroMobile® Ghost 3dB Gain NMO Antenna - MXTA25 MicroMobile® Whip 6dB Gain NMO Antenna - MXTA26 MXT575 MicroMobile® GMRS 50-Watt Two-Way Radio - MXT575
