WRFU
Everything posted by WRFU
  1. how to check your internet connection on your raspberry pi to see if it Wi-Fi or Connection or doing two connection at the same time.
  2. TeamViewer pc to pc
  3. we can do TeamViewer to log into my computer it's a free software just download this we be a Big Help everyone with a problem. This a Big Help with Raspberry and all computer Issues
  4. Ports - Custom Services Apply Cancel Service Name Protocol TCP/UDP TCP UDP External Port Range (1~65534) (Specify ports and/or port ranges spilit by commas, example: 30, 50-60, 65500-65510) Use the same port range for Internal port Internal Port Range (1~65534) (Specify ports and/or port ranges spilit by commas, example: 30, 50-60, 65500-65510) Internal IP address Check "Use same port range for internal port" Internal starting port (Leave Blank) Internal ending port (leave blank) Internal IP address (Enter the IP address of the raspberry pi) Click on "Apply" I can not leave it Blank, click Apply it will work
  5. the node is not connect on *323603 *70 *1172 *3172 the only thing the will do is reboot no TX or RX don't hear no one. The only thing I change is password, router setting. UDP, 4569
  6. thanks WQVX408 ​the raspberry reboot yesterday but not respond to the commands. I hear no now
  7. ok. I change it Sudo Reboot don't work it say -bash: Sudo: Command not found
  8. how to reboot the raspberry pi
  9. NETGEAR Router R7000
  10. Thank you so much I receiver more Information from you then mygmrs.net everyone who purchase a kit should receive more information on the kit. I'm going plug the raspberry pi into the router, unplug from my cat6 port switch now. Thank again
  11. I'M having problem linking in to the network. I try *100000 *1172
  12. Configuring your Router In order for your node to accept incoming link connections, You will need to forward a port in your router so that incoming connections can be passed to your node on your network. If you connect to your router's administration page you will find a section called port forwarding or virtual servers. Here, you can forward UDP connection on port 4569 to the same port 4569 on the Pi's IP address Consult your router's manual for how to set this up. Failure to configure this properly will cause only outgoing connections to work and potentially other issues. TYPE: UDP I check it out in my setting list was NO UDP.................. FTP HTTP ICUII IP PHONE NETMEETING/H.323 NEWS QUAKE II & III REAL AUDIO TELNET VPN_PPTP
