temchik
temchik's Achievements
Newbie
Newbie (1/14)
Reputation
  1. Falmouth, MA .675
  2. Well, aside from that one time when it worked, I could not make it work on the road anymore... gave up, used simplex instead, lost contact on many occasions but at least it worked
  3. Yeah, I meant 110.9
  4. There's still something wrong with this repeater info, it says 110.09 Pl In and Out, yet it doesn't work like that.
  5. It works! Apparently I need to key it up, release, and then start talking AFTER I hear the repeater open up! Newb
  6. Thank you for quick responses, guys! The repeater has both in and out codes set to 110.9, which I have programmed into my radios. If I set the RX code then I can't even hear the repeater acknowledgement. If I clear the RX PL I can hear it just fine, but my second radio does not receive my voice. I'm very close to the repeater....
  7. Hi All, I am a total newbie, having some trouble with a couple of things - I can hear some local chatter on 462.600 but they do not copy me at all. Is this because I have it setup with a wrong TX PL and no RX PL? Will radios receive all transmissions when no RX PL specified? - I am trying to use a local repeater to no avail. I setup the freq and shift and PL and can key it up and it responds, but my transmission is never relayed to other handsets. I've used another repeater before and it worked fine, just not this time... could I be missing something? Thanks!
