roggom
roggom's Achievements
Newbie
Newbie (1/14)
Reputation
  1. Thanks everyone for the responses.
  2. I have a Midland MXT275 with a magnetic mount. I have it sitting on a ditch light bracket on my hood and I get pretty good range. It uses the stock magnetic antenna, I have it RTV'd to the base to secure it a bit better. I was thinking to convert it to NMO for a more permanent mount, I have a Midland 3db ghost antenna and have a base. The coax is 1/8 from the factory at about 14' that I have payed out back and forth in the trimwell. Can I just cut the cable and solder in the new NMO mount. or does it require a certain thickness/ impedance cable for NMO. The current configuration gives me enough range for my purposes, but I would like something that is fastened to the bracket. Also If I do cut the cable, should I reduce the length? I currently only have a SWR meter that I used with my CB's back in the day. Not sure if I need another type of meter. Thanks
