wqur407
716 profile views
wqur407's Achievements
  1. I have been trying to get this 97s repeater to connect from a mobile connection. This time I have Starlink with a static IP address thru PureVPN. We have opened ports 222 tcp/udp and 4569 UDP only. I am able to ssh into the PI but not able to connect properly with the MYGMRS system. What am I missing? I have SIP AGL Passthrough open. Is there another protocol or something I need to allow? What is the IP that my node connects to?
  2. Yes please! I welcome any assistance!
  3. I have been able to connect to my new repeater, but I am unable to communicate between the two repeaters with my radios. DTMF does not work at this point! i was able to make the connection via the manage option https://network.mygmrs.com/manage/“node number" Steve WQUR407/W4STO
  4. Not an SDR! I have a Raspberry PI running Asterisk connected to a Kenwood TKR-820. My second repeater is an RT97s also connected to an RPI running asterisk. I need assistance setting up asterisk to identify the repeater on air and how to configure asterisk to allow me to connect and disconnect my repeaters using DTMF commands. It is my understanding these settings are configurable is asterisk but I do not have the knowledge to make the required changes. Steve WQUR407/W4STO
  5. Where do I configure my RPI to identify my station every 15 minutes on air?
  6. Edit /etc/apt/sources.list comment first line and add 'deb http://legacy.raspbian.org/raspbian/ stretch main contrib non-free rpi' Run sudo apt-get update Edit repeaterfinder.sh with your node number and password Run ./repeaterfinder.sh from the home directory The install should work now
  7. I would like to know what configuration file I need to edit in order for the repeater to id on air.
  8. I want to be able to connect my two repeaters and/or other repeaters as needed. Steve WQUR407
  9. I just purchased a portable repeater. I have an existing repeater node 23509 that in the past I could connect to other nodes. Today I cannot connect to any to the repeaters near me. When I key *3 (any repeater) connection fails, but I can hit the hub *3176! Please advise Steve WQUR407
  10. Is the 511 supposed to be programmable? I too have an old one that I would use if I could program it for repeaters.
