aroylance
Everything posted by aroylance
  1. that should work. just seems like there is an issue with the base setup
  2. What feed line are you using? in my little experience feed line is a big killer on UHF stuff. I can push over 15 miles on 5 watts with no issues but i am not trying to push through Florida vegitation. If you can hit it with your car and not the base i would think vegitation is not the issue. i would look at your coax size and your lightning arrestor. if the arrestor has failed it would not let much go through it. i think the common denominator is the base unit set up. i would buy an antenna and tune it for the GMRS band for the best results but unless there is a issues withs Ed's antenna it should get you eight miles pretty reliably. you have tried 2 differnt antennas without much differance so most likely something else in the set up. Just my .02
