W3NPA
W3NPA's Achievements
  1. Lately it's been working really well. Antenna height above terrain is not optimal, so my expectations were probably a bit too much. Thanks for the replies. Mark WRKM-215 / W4UDX
  2. It's always been only mediocre. Could be because my antenna is only mounted at the 40ft level. It hears way better than my HT, but that's not saying much. I have no test equipment. I'm guessing the radio is fine and my antenna is too low.
  3. Are odd repeater splits legal on gmrs? There's a repeater in KY that has an odd split...it listens on 21R and transmits on 22R. I didn't think that was allowed. Just curious.
  4. Well I would but the ham I bought them from programmed one to be a receiver and the other to be a transmitter only. I do not have the cables, software and experience to reprogram them, so that option is out.
  5. I have a repeater made from 2 old Motorola MCS-2000 radios. Coverage is good on transmit, but the receiver radio seems to have only mediocre sensitivity. I was wondering if an external FET preamp could be installed between the receiver radio and the duplexer, to make the repeater "hear" better. I know us hams use preamps for weak signal work on 2m, seems it could be done on FM on GMRS....
  6. I live in KY but have property in the mountains of north central PA in Potter County. The property is situated down in a valley below mountains on a four sides. I was just wondering...if I wanted to set up a low power mountain top repeater that's water proof and solar/battery powered, how expensive would that be? Also, it would be located on state owned forest land. How can I get permission to set one up? Setting up a repeater at my camp would be almost pointless as there are mountains in all directions....
  7. I use the Comet CA-712EFC. It's been a great antenna so far...
  8. I frequently travel through mid Ohio on my way to and from PA. There is a very active repeater that has users that have radios that have what I call an end of transmission screech. What kind of radios make that sound when you unkey? It's not like the typical bubble pack radio "Roger beep". Anyone have a clue?
  9. Deleted.
