div3405
Everything posted by div3405
  1. CommScope ‑ DB404‑B ‑ 450‑470 MHz 3.8/5dB Exposed Dipole Omni Antenna $395.95Neobits.com
  2. Here is a system that can be designed to communicate over IP. Multiple Puxing Repeaters at 15 watts analog. Cost about about $695. You add the Controller and you can setup multiple sites through the IP system. http://pxdz.manufacturer.globalsources.com/si/6008802219082/pdtl/Multi-band-repeater/1120755596/Small-portable-repeater-15W-use.htm
  3. Good point. I had not thought of it that way.
  4. Broadcastify is a great site for Scanner enthusiasts. However they don't allow GMRS repeaters to be monitoried. They allow amatuer radio repeaters and some of these repeater are not professional at all, such as: K6MWT 147.4350 MHz Los Angeles Renegade Repeater The "435" repeater is famous for lively discussion on controversial subjects. Located in Southern California on Santiago Peak (5,600 feet), the repeater covers Orange County, Los Angeles, San Diego and the Inland Empire. Most of the GMRS repeaters are used for emergencies and are very professional. Zello is being used as a means to talk and listen on a GMRS repeater. Just curious or is it even a concern? John n6hmz wqsz714
  5. div3405
    Untitled Album
  6. div3405
    Solar Powered GMRS Repeater
    I have installed several repeaters that run totally on Solar Power. They have been working now for 3 straight years without failure: I have installed Kenwoods 25 watt, BridgeComm 25 watt, and one repeater is a two ht with duplex and controller. They have all worked without losing power. Main power source is 140 watt solar panel, 30 amp control, and 100 AH battery. Talk time is calculated on 2 hours of continuous talk per day.
