WRKV653
WRKV653's Achievements
  1. I know this is an old post, but I am having the same issue. What did you do to resolve your problem?.
  2. Anyone else not able to log in and manage nodes?.
  3. WRKV653
    RT97S
    Thanks for the PDF, yes it is the courtesy tone and the repeater tail. When I let go of the PTT the repeater will drop out like normal, then the Pi keys up the repeater and the courtesy tone is heard, then after a 2-3 second repeater tail it all goes back to stand by. I am trying to find a setting in the Pi that lets me adjust the repeater tail time. Thanks
  4. WRKV653
    RT97S
    I am setting up a new RT97S repeater. I have ran into an issue that I can't seem to figure out. When anyone releases the PTT the repeater will key back up and give a beep noise. any suggestions on how to use the raspberry Pi as the repeater controller?. I am also using the mygmrs rt97s image. THanks
  5. I have been having the same issue, I can only connect to the hubs.
  6. Thanks Dale, I am checking the repeater settings to see if the issue is there. I see the node on the map and when I press the PTT the node changes color and I see it in the log. I can also trigger the test tone in simple usb tuner and it will broadcast the test tone over the repeater. I can *70 and get a system status of "repeater". I can't get back to the repeater tell tomorrow to check on the settings, but once I do I will update with what I find... Max
  7. I have been working on this for a few months now, and I am close to being online. I have emailed Rich many times and my last few emails requesting the same help (despite buying everything from him) have fallen on deaf ears... I can't seem to find much using the search... under the user, there is a section for Node managment. I don't have anything listed, is there suspost to be something?. I am finding conflicting information on correct DTMF procedure... I have looked in my rpt.con file and it shows *1 disconnect *3 connect. I will hold the PTT and press *3177 to connect to the intermountian hub. once I complete this I then *70 and I get nothing about being connected, only says monitoring. I do *85 and get the IP address. Also the node will say the time every hour over the repeater... But I can't seem to connect to any Nodes... I have set port 4569 to forward in the router as per the quick start guide. I then wanted to check if the DTMF was being recevied correctly, under run asterisk CLI client when I test the DTMF I get a hangup after every number pushed, shouldn't this be seemless and only show a hangup after the PTT has been released?. Thanks for any help that can be offered! Admin for Node 21605 and Seeksafety repeater WRKV653
  8. I am needing some help setting up my repeater. Icom CY7300 repeater going into a DMK radio interface. I bought a custom cable from mygmrs and some how lost the repeater setup instructions. is there anyone that can help???
