WRUA294
About WRUA294
  • Birthday 07/29/1951
    William B. Walker
    Arden, NC
  • Interests
    SW listening, scanners, GMRS
569 profile views
WRUA294's Achievements
  1. There is a firmware upgrade that changes some of the colors and makes it much easier to read.
  2. The app is opening and working fine now on my Android 6.0 device. Thanks for looking into this.
  3. Installed new version but it won't accept my username/password when entered. Says my credentials are incorrect.
  4. Sounds like I'm out of luck.
  5. That's the problem, there is no where to login when the user login screen comes up.
  6. Downloaded the 1.3.0 version and installed it on my Android 6 network radio. It would not let me register. Went back to the Google Play Store but no "Join the Beta" option came up so no luck.
  7. I received my Wouxun KG-935G on Monday and the new KG-935 Plus was released on Tuesday.
  8. I tried two different GMRS 9R's and both of them had reception problems. Transmitting was fine but when it came to receiving signals, they were deaf as a stump. I've never owned a UV-9G so I don't know if they have this problem or not. If you must have a radio with the IP67 rating, you might want to bite the bullet and buy a Wouxun KG-S88G.
  9. The GM-15 (which is the same radio as the Radioddity GM-30) is not yet supported in Chirp. Go to Radioddity's website and download the programming software for the Radioddity GM-30. Works like a charm in Windows but don't know if it works with a Mac or not.
  10. I continue to be impressed with my GM-15 Pro.
  11. If you're programing the repeater on a repeater channel, it will transmit the offset automatically. You shouldn't have to do anything except program in the CTCSS or DCS tones for that particular repeater.
  12. It's black and it's the second one I've tried. Just as a side note, these radios seem to transmit ok but have very poor reception. Have you noticed this?
  13. My GMRS 9R actually displays the FM frequencies on the screen but doesn't receive them.
  14. If your laptop has a regular cd player, it should also play a mini cd.
