WRUB458
Everything posted by WRUB458
  1. Is this good?
  2. Hello there! Ok I’ll keep that in mind when I set up! Thanks
  3. Ok sounds good. Do they have to be grounded or anything? I may give a try….
  4. Thoughts on this antenna for my Wouxun 1000…..
  5. Well I did it. I purchased the Wouxun KG 1000 from buy two way radio. Done. That and my 905’s …antenna is all that left for the 1000….thoughts?
  6. Do you guys know if any other decent stores to buy these mobile radios from besides buy two way radios and mygmrs?
  7. “If you use that same transceiver to communicate directly to a mobile radio, it is functioning as a base station. The difference is in usage. Referring to a radio as a base station doesn’t prohibit it from being used to communicate through a repeater.” You make things clearer for me and I appreciate that! Thank you
  8. Axorlov, any suggestions of a great 6db antenna to use with Wouxun kg 1000?
  9. I cannot use wifi or any device w Bluetooth capabilities. Thank you Shannon! However, I do like as much info as possible that I can absorb even though I’m new to it all. With that said, base can be a less powered unit but with a 6db or 9db antenna to make stronger?…which one recommended….better yet ….what do you suggest for base? I’m leaning toward Wouxun!
  10. Thank you once again. I’ll do testing here with the radios for distance and repeater existence and visibility. I will post my findings. Much appreciated.
  11. Hi there and thanks for responding. I was looking at like the midland mxt500 or so vs the wouxun. I was wondering if the radios I have would work with the midland mxt500 if I wanted that one. I have to check on repeaters as I’m new to this. And, what base antenna would be recommended?
  12. Hi everyone! I have call sign and license! Situation. I have to stay in contact w family less than 10 miles down road urban area. I cannot use cell phones at work so I bought wouxun kg-905g radios w nagoya 771g and wanting to add home base for added range. Thinking of wouxun kg 1000 or would midland work w it?
