WRUR505
    Jeremy
  • Interests
    2 way adio, firearms, engine repair, family
WRUR505's Achievements
  1. It's been a while so i might be wrong but I do not believe you can edit an existing channel on the fly with the uv5r. It doesn't save edits to an existing channel memory slot. Tune to your receive frequency, enter your tones and offset and save in an empty channel memory slot.
  2. I have the exact same setup as you. I get great results. Have you checked the SMA to SMA cable that goes from the HT to the amp? Eliminate the Amp and try the UT72 straight to the HT. Something isn't right based on my experience with the same setup.
  3. It appears that Tipp City repeater covers Dayton. https://mygmrs.com/map/4895
