Andrei
Everything posted by Andrei
  1. I noticed something weird, at least to me, when I use the scan option on my Wouxun KG-935G. The scan begins, and then it stops for a few seconds on various frequencies and then resumes. But when I listen, there is nothing but static. Yet the green light goes on and the blue signal bar shows a strong signal. Why is that? None of my other radios (Baofeng UV-5G, Baofeng UV-9G, BTECH GMRS Pro) do that. I tried playing around with the squelch, but the behavior remains. Can somebody explain what is going on? Also, I tried to see how the scanning works and I keyed up one of my other radios (say the UV-5G) and I noticed that as soon as I keyed up, the Wouxun KG-935G would stop scanning, but it would stop on the wrong channel. I was keying up on GMRS 18 and the radio would stop on a repeater channel. Could it be that in close proximity to the emitting radio the Wouxun KG-935G detects maybe some kind of "harmonics" or bleed-over into other frequencies? Can somebody explain this or did I get a lemon with serious scanning issues? Do I need to educate myself on the Wouxun KG-935G or do I need to return the unit? Thanks for any help!
  2. yes, thank you, that worked perfectly ?
  3. Which strongly suggest to me that the software was botched in its design. I will go with CHIRP which I trust much more.
  4. thanks, but now since I am back to my (Linux) comfort zone, I think I will stick to it! But thank you for your clarification!
  5. thank you MichaelLAX!!
  6. I gave up on trying to get Windows to work (frankly, I hate it and find if baffling in its illogical complexity). I have no idea why exactly I could not get it to work with Windows (in my case Windows 10) but if I can use CHRIP on Linux I am a very happy camper ? Windows might be too complex for my tiny brain, Linux is for dummies, including me!
  7. I don't use Venmo, but I will bestow upon you my eternal gratitude ? also, to thank everybody here, I was thinking of posting a review of my radios "for noobies by a noobie", maybe that will help others in their first steps ? Kind regards, tons of thanks, and Merry Christmas!!
  8. LOL, okay fair enough, but just tell me (the dodo-brain) which column exactly is for the repeater input and output tones and I will keep my promise!?
  9. Actually, I finally managed to get CHIRP working on Linux! So my final question: in CHIRP, where do I set the repeater input and output tones? Thank you in advance for putting up with me! ?
  10. The device manager found this: Location: Port#0005 Hub #0001 (so the new COM port has appeared I suppose, port 5) But when I tried to use it I got this message: "The drivers for this device are not installed. (Code 28) There are no compatible drivers for this device. To find a driver for this device, click Update Driver." When I try to update the driver I get this: "Windows was unable to install you CP2102 USB to UARD Bridge Controller. Windows could not find drivers for your device" On the Wouxun software, I cannot pick a port, under the "port" menu, all the ports are greyed out and port 1 the only one checkmarked. and when I try to read from the radio I get this message: "Failed connection! Please check if powered ON or well connected the com port!"" One the CHIRP software I cannot see ANY ports from the dropdown menu. Any ideas?
  11. Sorry, but which menu specifically is it? RX-CTCSS TX-CTTSS RX-DCS OR TX-DCS or all four (input on RX-CTCSS and RX-DCS and output on TX-CTCSS and TX-DCS?). Sorry for being such a noob! ?
  12. When I use this cable on Windows, it does not "see" the radio. Frankly, I have not used Windows since 2000 (have been on Linux instead). How can I find out to which USB port my cable is connected and what I shall call it from inside either the Wouxun software or CHRIP (for Windows)?
  13. Thank you so much. OffRoaderX, your videos and your presence here have been a huge help for me!
  14. So I broke the piggie bank and got myself a Wouxun KG-935G for Christmas ? First impression? Love the radio! But, having read the user manual several times, I still have 3 questions: 1) Where/how do I assign repeater input and output tones? 2) the second channel window shows "KG-935G" (if I do not have dual channels enabled). Can I change that and, if yes, where (I would like to place my callsign). Alternatively, the very top like also reads "Wouxun KG-935G" - can I place my callsign there and, if yes, how? 3) I got the programming cable and driver on a mini-CD, but I don't have a CD/DVD player. Can I download that driver somewhere (I used WIndows 10)? Right now, the KG-935G programming software cannot "see" the radio and the "com" menu is greyed out. Thank you! PS: I tried the CHRIP software tool too but I could not get it to work under Windows and Linux, but with Windows it does not see it, and with Linux I have permission problems ? so, if at all possible, use the radio without any programming software
  15. thank you both for your help in making sense of the manual! I am a noobie (as you can tell from my questions) and the manual (and app) are confusing to me. Many thanks!!
  16. I own Btech GMRS Pro and I have six questions about it: 1) When I simply press the "scan" button how can I monitor what frequencies are actually being scanned? Right now all I see is a "Z" 2) does the unit only scan the GRMS and repeater channels or does it scan all the frequencies between 136MHz-174MHz, 462MHz-468MHz and 400MHz-520MHz? 3) Is there a way for me to make the unit scan ONLY the GRMS+repeater channels? If yes, how? 4) Is there a way for me to make the unit scan only the VHF frequencies? If yes, how? I also noticed that when I press the scan button the unit stops are the first channel/frequency which it detects and just stays there forever. My question then is 5) Is there a way to make the unit "resume scan" after a determined time (say 10 seconds unless I press a button)? Finally, 6) Can I manually assign a specific frequency, say Marine Channel 16 (156.8 MHz) to the unit and monitor it? If so, how? I thank you in advance for your replies.
  17. I have purchased a Btech GMRS-Pro and I love it! I just have two questions about it: If monitor two channels, say one GRMS and one repeater channel, will the radio still be ready to receive NOAA warnings if I set NOAA on "WX alert"? Because if yes, then it means that the radio actually monitors 3 frequencies, the two channels PLUS NOAA, right? Also, when traveling, do I need to scan and select the local NOAA channel and somehow select it for the "WX alert" feature to work or will the radio do that automatically while I travel? Thank you
  18. Hi I have just received a (very nice) BTECH GMRS-PRO (https://smile.amazon.com/dp/B0B4BLZ67Z) and I would like to replace the original antenna with a Genuine Nagoya NA-771G. My problem is that I am not quite sure which one to pick (none of the ones I have seem to fit this base). I have attached a photo of the base of the antenna for this radio. Could anybody please post an Amazon link to the Nagoya NA-771G version I need to purchase for this radio? Many thanks in advance!!
  19. Understood ? Thank you all for your replies! Oh, and OffroarderX - thank you for your videos, they made me purchase my first GMRS radios and I love them!
  20. well then, I will follow up with another "noob" question: where can I learn the proper terminology to use? Stuff like "break" or "roger" or "over" etc? is there some kind of reference of such terms specifically for GMRS?
  21. thank you all for that excellent advice!
  22. Hi I have a Baofeng UV-9G which I use a Nagoya NA-771G 15.3-Inch Whip GMRS (462MHz) antenna. I am tempted to purchase a longer ABBREE SMA-Female Dual Band 144/430Mhz 28.3 Inch antenna. Would that be a good choice and what difference, if any, could the ABBREE foldable antenna make for me? Thank you
  23. thanks, this does make sense. and yes, so far everybody in the GMRS world was super friendly to me, including in this forum where I got several questions quickly and very helpfully answered ?
