Lscott Posted May 16 Report Posted May 16 As usual somebody has an over the top mobile radio installation. And some here complain they can’t find a place to mount one or two radios? Maybe they haven’t tried hard enough. Jaay, FishinGary and WRTC928 1 2 Quote
OffRoaderX Posted May 16 Report Posted May 16 I guarantee that dude has never seen real boobies in his entire life... Haroldo, Bogieboy01, tweiss3 and 6 others 1 2 6 Quote
Lscott Posted May 16 Author Report Posted May 16 11 minutes ago, OffRoaderX said: I guarantee that dude has never seen real boobies in his entire life... Quote
WSHH887 Posted May 17 Report Posted May 17 2 hours ago, OffRoaderX said: I guarantee that dude has never seen real boobies in his entire life... Dude, you're from California. It's getting harder and harder to find real boobies here any more. WRUE951 1 Quote
OffRoaderX Posted May 17 Report Posted May 17 12 minutes ago, WSHH887 said: you're from California. It's getting harder and harder to find real boobies here any more i'm old enough to remember when they were all real. WRUE951 1 Quote
Lscott Posted May 17 Author Report Posted May 17 19 minutes ago, Socalgmrs said: That’s not very green. Looks Gray colored to me. Quote
Lscott Posted May 17 Author Report Posted May 17 2 hours ago, WSHH887 said: Dude, you're from California. It's getting harder and harder to find real boobies here any more. Likely getting harder to find “real” women there too. Quote
Jaay Posted May 17 Report Posted May 17 10 hours ago, Lscott said: Likely getting harder to find “real” women there too. Any day now, Scamazon will be importing their Brand New LoveBot 3000's complete with spermicide ! Lscott 1 Quote
Lscott Posted May 17 Author Report Posted May 17 This is just part of the flea market area. Sitting in the grand stand area taking a break. Quote
Lscott Posted May 17 Author Report Posted May 17 Buying some antenna stuff. Got the Diamond NR240CA wide band antenna just to screw around with. Picked up the optional spring lower section for the Comet CA-2x4SR wide band antenna. Finally got the super flex dual band antenna with the BNC connector to use with the HT SMA/BNC adapters. WRUU653 and Jaay 2 Quote
tweiss3 Posted May 17 Report Posted May 17 It is just a out the nicest day here. Lscott and Jaay 2 Quote
FishinGary Posted May 17 Report Posted May 17 18 hours ago, Lscott said: As usual somebody has an over the top mobile radio installation. And some here complain they can’t find a place to mount one or two radios? Maybe they haven’t tried hard enough. Q: Which band are you working today? A: Yes. It's been interesting following the FTX-1 pre-order drama online, I guess. People walking into Hamvention and walking out with one, while pre-orders have not been shipped yet. Seems like HRO is shipping out orders now though. GreggInFL and WRUU653 2 Quote
Guest Posted May 17 Report Posted May 17 14 hours ago, Lscott said: Likely getting harder to find “real” women there too. Why is L-O-L-A Lola going through my head right now? Quote
WRUE951 Posted May 17 Report Posted May 17 21 hours ago, OffRoaderX said: i'm old enough to remember when they were all real. Real ones were so much better, it never entered your mind that the ones you were playing with could have been made in 'China' Quote
WRTC928 Posted May 25 Report Posted May 25 On 5/17/2025 at 11:43 AM, Lscott said: Picked up the optional spring lower section for the Comet CA-2x4SR wide band antenna. That 2x4 is a pretty remarkable antenna. I get good performance on GMRS, 2m, and 70cm, and the SWR/Smith graphs are nearly perfect on MURS and 1.25m as well. The graphs don't show how well an antenna can transmit on a given band, and I'm a little skeptical that one antenna can perform well on 5 bands, but at some point, I'll try it on 220 and see what I get. It would be great if it could do 220, because that would mean I can put the Anytone tri-band radio in my little car and use only one antenna. There are tri-band antennas out there, but so far, I haven't found one that gives me good SWRs on 140, 440, 220, and GMRS. I don't want to give up GMRS, so I'd need another antenna for it. I don't care much about MURS. It's nice to know I have the capability if I need it, but I've literally never used it, and I'd give it up for good performance on the other 4 bands. Jaay 1 Quote
Lscott Posted May 25 Author Report Posted May 25 6 hours ago, WRTC928 said: That 2x4 is a pretty remarkable antenna. I get good performance on GMRS, 2m, and 70cm, and the SWR/Smith graphs are nearly perfect on MURS and 1.25m as well. The graphs don't show how well an antenna can transmit on a given band, and I'm a little skeptical that one antenna can perform well on 5 bands, but at some point, I'll try it on 220 and see what I get. It would be great if it could do 220, because that would mean I can put the Anytone tri-band radio in my little car and use only one antenna. There are tri-band antennas out there, but so far, I haven't found one that gives me good SWRs on 140, 440, 220, and GMRS. I don't want to give up GMRS, so I'd need another antenna for it. I don't care much about MURS. It's nice to know I have the capability if I need it, but I've literally never used it, and I'd give it up for good performance on the other 4 bands. There is a similar antenna from Diamond. It’s the NR240CA. https://www.diamondantenna.net/products/NR240CA The full spec’s are in this PDF file. https://www.diamondantenna.net/static/pdfdocs/NR240CA.pdf Jaay and WRTC928 2 Quote
