plarkinjr Posted August 1 Report Posted August 1 I have various models of Baofengs, Retevis, RadTels, and Wouxuns. Each has some features the others don't, but none have all. I wish someone would make a radio with the features listed below (roughly in order of preference). If such a radio exists, please let me know. [_] Chirp programmable [_] 10+ character customizable channel names (sorry Midland) [_] No keypad (just a handful of buttons: front panel, programmable sidekeys, etc. for less technical users.) [_] 24+ memory slots capable of storing GMRS repeater frequencies and split-tones (100+ channel memory slots overall) [_] Display readable in full sun, with adjustable backlight for night-time. [_] Dual-Band/Dual-Watch Rx VHF & UHF (for analog fire/safety, HAM, Marine, etc) [_] "Zones": allowing you to group channels by user need. (e.g. only GMRS, only HAM, only your town, neighboring towns, etc) [_] at least 4 zones, each capable of storing at least 20 channels [_] switch zones by one key press [_] USB-C charging on the battery [_] Drop-in desk cradle for charging [_] BNC or SMA antenna connector [_] IP54 or better rating for dust/water protection [_] Scanner with [_] scan within zone, or across all memory channels [_] temporary channel lockout [_] 5+ watts Tx output at 462-468 MHz [_] Channel KNOB (preferably with 16 to 20 clearly marked stops) [_] Rx AM Air band [_] NOAA with "SAME" alerting technology [_] FCC Type Certified for GMRS Features I don't care about: [_] GPS (esp. w/ proprietary sharing of that info) [_] DTMF [_] Man-Down/Lone-worker function [_] Broadcast FM radio reception The Wouxun KG-935 gets close, and I really like it. However, the 10-key pad isn't really a necessity. It means the "useful" buttons have to be small in order to fit the space, and they add potential for non-technical user error. The KG-905G Plus appears to have the button set I want, but it doesn't tick enough of the other boxes. Any suggestions? Quote
WRUE951 Posted August 1 Report Posted August 1 5 minutes ago, plarkinjr said: I have various models of Baofengs, Retevis, RadTels, and Wouxuns. Each has some features the others don't, but none have all. I wish someone would make a radio with the features listed below (roughly in order of preference). If such a radio exists, please let me know. [_] Chirp programmable [_] 10+ character customizable channel names (sorry Midland) [_] No keypad (just a handful of buttons: front panel, programmable sidekeys, etc. for less technical users.) [_] 24+ memory slots capable of storing GMRS repeater frequencies and split-tones (100+ channel memory slots overall) [_] Display readable in full sun, with adjustable backlight for night-time. [_] Dual-Band/Dual-Watch Rx VHF & UHF (for analog fire/safety, HAM, Marine, etc) [_] "Zones": allowing you to group channels by user need. (e.g. only GMRS, only HAM, only your town, neighboring towns, etc) [_] at least 4 zones, each capable of storing at least 20 channels [_] switch zones by one key press [_] USB-C charging on the battery [_] Drop-in desk cradle for charging [_] BNC or SMA antenna connector [_] IP54 or better rating for dust/water protection [_] Scanner with [_] scan within zone, or across all memory channels [_] temporary channel lockout [_] 5+ watts Tx output at 462-468 MHz [_] Channel KNOB (preferably with 16 to 20 clearly marked stops) [_] Rx AM Air band [_] NOAA with "SAME" alerting technology [_] FCC Type Certified for GMRS Features I don't care about: [_] GPS (esp. w/ proprietary sharing of that info) [_] DTMF [_] Man-Down/Lone-worker function [_] Broadcast FM radio reception The Wouxun KG-935 gets close, and I really like it. However, the 10-key pad isn't really a necessity. It means the "useful" buttons have to be small in order to fit the space, and they add potential for non-technical user error. The KG-905G Plus appears to have the button set I want, but it doesn't tick enough of the other boxes. Any suggestions? you describe a Baofeng UV 25 or or UV 21 with one cavoite,, your stuck with they key pad Quote
