Nfranks97 Posted March 24, 2019 Posted March 24, 2019 Want to put a gmrs radio in my semi and have been thinking of putting the midland mxt400 in it but I am open to any all other radio recommendations Quote
0 kidphc Posted June 27, 2019 Posted June 27, 2019 Flew RC Heli for many years, I found the dean connectors a pita to solder. Often depending on the angle and length of wire there was excessive strain on the solder joints for the deans. They were a real pain to disconnect if you were even a bit sweaty. I switched to the Anderson Power poles when my setups for the helis started venturing into high voltage systems. I found that wicking the lead, then crimping then running a bit of solder worked the best. Plus you can slide them together to form a "T", use roll pins to lock them side by side or buy a plastic connector to lock the ends together. I've actually hot glued some to parts to secure them. The only real negative I found was the length of the connectors when connected. Quote
Nfranks97
26 answers to this question
