Change username
Guest Johnny
Is there a way to change my username? I've tried the edit profile link but it doesn't provide the username as an editable field.
Are you a REGISTERED MEMBER at the main MyGMRS Repeater listing website?  If so, what is your registration username there?
( Only licensed GMRS and AMATEUR operators can register at the main site, as well as here at the Forum once approved.  Main site registrations are keyed to the FCC database and the site software compares your registration data with the FCC database. If the site software verifies your FCC license, it will register you at the main site.  Once that takes place, you can then register here at the Forum manually and user options increase. )
