Linking to network
19 answers to this question
*1xxxxx = Disconnect
*2xxxxx = Monitor only (you can hear them, they cant hear you)
*3xxxxx = Connect
*70       = Status
*811xxxxx = Permanent Disconnect
*812xxxxx = Permanent Monitor
*813xxxxx = Permanent Connect
169 Midwest Region
172 Northeastern region
174 Southeastern Region
175 Southern Plains region
176 Southwestern region
177 Mountain region (West Coast)
Ensure you have a good internet connection (preferred wire-line internet over wifi. DO NOT USE BOTH, it confuses the program)
For more info on regional hubs, please visit https://mygmrs.com/nets
Any more questions, feel free to ask :)
I'M having problem linking in to the network. I try *100000
        *1172
Thank you
so much  I receiver more Information from you then mygmrs.net everyone who purchase a kit should receive more information on the kit.  I'm going plug the raspberry pi into the router, unplug from my cat6 port switch now.
Thank again
  On 9/26/2020 at 11:21 PM, WRFU said:
Thank you
Thank again
The cat6 port shouldn't matter, if you have active connections through the switch then the pi should work as well. Also dont forget to add the port forwards to allow incoming signals to be sent to the pi. I'll send you a note with the numbers as for hacking reasons, this info is not posted publicly (to my knowledge)
Ok, in the screens you showed me with port forwarding, make sure the port forward circle is selected then click "Add Custom Service"
This will give you a new screen.
Fill in the following info:
Service name: GMRS Link
Service type: UDP
External Starting Port: 4569
External Ending Port: 4569
Check "Use same port range for internal port"
Internal starting port (Leave Blank)
Internal ending port (leave blank)
Internal IP address (Enter the IP address of the raspberry pi)
Click on "Apply"
This should add the UDP port for the pi.
As for rebooting the Pi, there are two ways. The first is to log into the pi (whatever username/password you set, if you did not set a password, it is likely repeater, 123456) then type Sudo Reboot. It should reboot the pi. The second is to just unplug the pi, not the best way, however if you do not have a screen and keyboard set up for the pi, this is usually the easiest way.
the node is not connect on *323603 *70 *1172 *3172 the only thing the will do is reboot no TX or RX don't hear no one.
The only thing I
change is password, router setting. UDP, 4569
Ports - Custom Services
   Apply                Cancel
Service Name Protocol                  TCP/UDP                 TCP                 UDP External Port Range (1~65534) (Specify ports and/or port ranges spilit by commas, example: 30, 50-60, 65500-65510)  Use the same port range for Internal port
Internal Port Range
(1~65534)
Internal IP address
Click on "Apply"   I can not leave it Blank, click Apply it will work
   Apply                Cancel
Internal Port Range
(1~65534)
Internal IP address
In all honesty I am at a loss as to what else can be done without having the computer, repeater, and pi directly in front of me. These systems do take a fair amount of computer tech understanding to get working properly.
we can do TeamViewer to log into my computer it's a  free software just download this we be a Big Help everyone with a problem. This a Big Help with Raspberry and all computer Issues
