  • 1 month later...
I downloaded the software from Radioddity. Mine came with not only "non ham band Tx" locked, but they locked me out from RX on everything else too - so no weather channels, no listening to airband, no listening on AM stuff ... so I had to get the OEM software to unlock it.
Then I used Chirp to program the channels, and changed some settings (channel step, turned beep off, etc) ... then went to change something or add a channel with Chirp and it set it right back to the defaults - really frustrating. I don't blame you for not wanting to use Chirp. If I had a windows machine I woudln't use Chirp for that radio either!
No sense buying programming kits if you already have the cable right?
