cant hear the feed in the nationwide hub live
The national hub isn't connected to any of the other hubs right now so there is nothing to listen to. Watch the map and find a regional hub with a nodes that show "Red" which means they are transmitting. Listen to that hub. Hub 169 is pretty active.
  • 3 months later...
On 11/24/2021 at 1:57 PM, WRFP399 said:
This noid isn't connected to a hub. It's only connected to the two others but it will show you what I mean by "red"
Do you have to connect too a HUB only? or are you able to connect to another NODE? new to this system and it's a bit confusing.
