firefighter2 Posted December 21, 2014 Report Posted December 21, 2014 Good AfternoonI am looking to setup a new repeater and will most likely be using Kenwood Mobles, Any advice or Equipment requirements that need to be considered.Thanks in advance.WQVA584 Logan5 1 Quote
zap Posted December 21, 2014 Report Posted December 21, 2014 Know what radios you're planning on using? Know if you will be using a single antenna or dual antennas? Do you know where the planned location for your repeater will be? One thing to take into consideration, what kind of use are you expecting? Heavy, light, occasional check-in's, etc. If your going with a mobile base that can often dictate the power output you can run. Quote
PastorGary Posted December 22, 2014 Report Posted December 22, 2014 Hello Eric and welsome to MyGMRS Forums. Thanks for registering here. Quote
