Hello All,
Thanks in advance for your help and patience.
On a homebuilt DIY antenna,   is there any reason, other than ease of repair/maintenance,  that a coax cable could not/should not be connected directly to the antenna?  The point is to eliminate one connector (NMO, PL259 etc) and with it one possible point of failure.
David
For the sake of the general question, assume the antenna and the feed-line are both 50 ohms.  (yes, unlikely, I know).
Point being,  does the connector have any function other than convenience ?
I see some ladder-line antennas connected to the coax with only a choke made of 'turns of coax'.
  • 2 months later...
