WRPW641 Posted April 28, 2022 Report Share Posted April 28, 2022 Good Morning, I picked up a Btech GMRS 50x1 for a base station I cant put up a tower looking for an eve mount compatible antenna and cable recommendations! also a mount! Any info is appreciated Thank you WRPW641 Quote Link to comment Share on other sites More sharing options...
WRMB269 Posted April 28, 2022 Report Share Posted April 28, 2022 Mount https://www.amazon.com/Skywalker-Signature-45-60in-Adjustable-Mount/dp/B009P78R68/ref=sr_1_1_sspa?crid=2XI9IJ7I0LN9T&keywords=eve+antenna+mount&qid=1651157149&s=electronics&sprefix=eve+antenna+mount%2Celectronics%2C76&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyVTFFTzdQRFo5STNUJmVuY3J5cHRlZElkPUEwMzc4OTEwVjM5QTJOMlI0MVQwJmVuY3J5cHRlZEFkSWQ9QTAxMDM5MzgyWDVUTENGNkI5STFOJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Coax LMR240UF for runs shorter than 25ft LMR400UF for anything over 25FT Example of LMR240UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/173767279461?hash=item2875564365:g:NbIAAOSwMSRfSTbj Example of LMR400UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/184232597543?hash=item2ae51e5827:g:KDEAAOSwlsVegeNH Antenna (don't get obsessed with gain claims) The most important factor that will effect performance is how high the antenna is get it as high as you can!!!!!!!! Option 1 (ready to install) https://www.amazon.com/HP-50-N-460-470-GMRS-Band-Antenna/dp/B08N17RRKT/ref=sr_1_3?keywords=gmrs+base+antenna&qid=1651157772&s=electronics&sprefix=gmrs+base%2Celectronics%2C95&sr=1-3 Option 2 (cheaper but need to use your own pvc pipe) https://www.kbcubed.com/DBJ-UHF-5dB-GMRS-Antenna-by-Ed-Fong-p379488596 Hope this helps you get started and good luck welcome to GMRS ! Quote Link to comment Share on other sites More sharing options...
