Guest David Hardy Posted June 22, 2022 Report Posted June 22, 2022 Hi I need some help programming a radioddity GM-N1 handheld I cannot figure it out. Ohio, Indiana boarder Quote
SteveF Posted June 23, 2022 Report Posted June 23, 2022 5 hours ago, Guest David Hardy said: Hi I need some help programming a radioddity GM-N1 handheld I cannot figure it out. Ohio, Indiana boarder Chirp does not support it as if yet. Do you have a programming cable? Try going here to program. https://radioddity.s3.amazonaws.com/Radioddity_GM-N1_CPS_V1.01_20210824.zip Quote
WRQX963 Posted June 25, 2022 Report Posted June 25, 2022 Here is a little tip that I stumbled across for channels 23-30 only: When you change an Rx frequency, its corresponding grayed out Tx frequency will change automatically, but the vocal channel numbers will NOT change. Quote
