Is anyone using this repeater and controller? I saw the the DB-9 Connector to URIxB Pinouthad a tab for the ID-O-Matic IV. I can't be the only one who has this since the pinout is posted.
I don't exactly want tech support but I don't see any recent posts about these two items together. This may be a good opportunity for others to verify it works as a fun "cheap" solution.
-edit
I disconnected the ID-O-Matic as the repeater works fine without it. Not sure why I have inconsistent issues.
When I key up, it works fine.
Then you do it again and there is a trail.
When looking at the controller using putty I can see CORE enabled , highlighted
Sometimes when I update the programming and keep it connected it will either stayed keyed up with noise until I remove power or work perfectly until I power cycle the controller.
Since my repeater works without issue when not using the controller I :
Have an issue with the controller
Have a defect with repeater's serial or sound card
Is it possible these devices do not play well together?
HrXkb3UjmgFvBe
Hi,
Is anyone using this repeater and controller? I saw the the DB-9 Connector to URIxB Pinout had a tab for the ID-O-Matic IV. I can't be the only one who has this since the pinout is posted.
-edit
Update to my post
1 answer to this question
