Chirp Programming
4 answers to this question
2 hours ago, WRTJ886 said:
In Chirp, the code should be listed as "155" under the "DTCS Code" and/or "DTCS Rx Code" depending on if you want to use different Tx and Rx codes.
Unmentioned: DTCS Pol would likely be "NN" (send/receive I presume).
1 hour ago, WRUF685 said:
Thank you both, I thought you were to use the chart!!!!  Thanks again, makes more sense why I was having trouble. Thanks again
Since you didn't state what radio is in use, one can not look up the manual. Most radios I've seen that use a "chart" are pre-2017 bubble-pack radios from Midland and Motorola (and the Midland MXT series of mobiles). And that is likely because they don't have display space for the real tone designations, hence the use of a linear numbering scheme.
I'm sure if you try to program a channel /on/ the radio, you will find you need that chart.
