7 hours ago, WRQD950 said:
Just for everyone's information if the battery on the KG-805G is depleted pretty bad the red charge indicator light will flash but will soon go to solid red.
The 805 manual has a noticeable missing section: Battery Charging!
From the 935 manual:
Quote
When a completely drained battery is first inserted into the charger, the charger
will switch to trickle charge mode and the LED will flash red continuously.
▪ After 10-20 minutes the charger will switch to normal charging mode and the
light will turn solid red. The LED will turn green when charging is complete
