m4f1050 Posted November 3, 2022 Report Posted November 3, 2022 Does anybody have the pin schematic/assignment for the DB25 M to M in order to connect the URIxB to the VXR-7000? Quote
0 m4f1050 Posted November 9, 2022 Author Report Posted November 9, 2022 Solved. Needed COR signal, mod is posted on Adding a COR PLUS CTCSS Detect Signal to the Yaesu VXR-7000 Repeater No need to do last part of instructions of adding a transistor since URIxB accepts Active Low signal. Quote
0 m4f1050 Posted November 7, 2022 Author Report Posted November 7, 2022 Found some help on this external link AllStarLink Community: URI Hook up for Yeasu VXR-7000 (Angeo and Kevin) I get the connect/disconnect messages from PI, still working on it... Need to check PI conf files... Quote
0 rhodesjim1 Posted May 17, 2023 Report Posted May 17, 2023 I’m working on connecting the URIxB to my VXR-7000. Is everything working as you expected? Do you feel you needed to COR Signal Mod? Also, can you share the configuration changes for the radio in the software? Did you use simple usb or usbradio? Thanks Jim K0JNR/WRKA462. Quote
m4f1050
3 answers to this question
