Wouxun KG-UV9G Pro CTCSS or DCS scanning
Does anyone know the right menu function to use while a frequency is transmitting to scan for CTCSS or DCS codes? I can't seem to make this work. I understand that someone must be transmitting. Is menu 51 correct? Can't make it scan if it is.
Thanks,
Jim
3 answers to this question
Thanks,
Jim
If this is similar to my 935 -- I found I had to assign it to a (short-press) side button.
Note that CTCSS and DCS are /separate/ scan functions, and if you want both readily accessible you'd need two button assignements.
Press MENU, press up arrow to SCN-CD, press MENU again to CTSS (press MENU again to DTS), wait for someone to transmit, press MENU to scan CTSS code.
 Watch NotaRubicon on youtube, Good Luck.
