  On 6/14/2023 at 1:29 AM, Bamishere said:
How make one side gmrs and other repeaters? amybody know?
Expand
Bring up the KG-1000 software and go to the "Scan Group" tab and create two scan groups such as GMRS and Reptrs (you are limited to 6 characters).
Assign each scan group what channels you want assigned to that group - must be sequential channel numbers. By default the GMRS simplex channels on the KG1000 are channels 1-22 and the repeater channels are 23-30
Load the "GMRS" scan group on the left VFO (display) and the "Reptrs" on the other
A few things to consider:
See the below example - since the scan list works by sequential channel numbers, its a good idea to save frequencies to channels numbers in groups and leave gaps for adding new channels to that scan group. If you are scanning something like 70cm ham repeaters then save those channels as channel 200-299.
The KG-1000G+ I had (first week they came out) had a bug on dual scanning. Instructions say start scanning on one side, press the band button to go to the other side and hit scan and you can scan both sides at once. There is/was a bug that pressing the band or scan button (sold the radio, forgot what button) to change sides on the radio itself to start scanning on the one side then the other side would stop scanning. If you hit the button on the microphone it works fine. Don't know if that's still the case.
  • 2 weeks later...
  On 6/25/2023 at 4:11 PM, Bamishere said:
Still nothing,I have GMRS 1-14, Repeaters 15-27 in scan group can't get to show both on screen?
Expand
Expand
Thanks a bunch,finely got it to work.
