randallbonin Posted March 2, 2024 Report Posted March 2, 2024 Suggestion………. Under the main menu, when I select “Map”, it always defaults to “Satellite Streets”, which is very difficult to see clearly. Each time, I must manually select “Street Color”, which is the very best view in my opinion. I suggest that the default view be changed to “Street Color”, or at least use the last setting used. BTW, your website is excellent. Thanks so much, Randall Bonin WRPM538 Quote
