LeoG Posted Sunday at 02:12 AM Report Posted Sunday at 02:12 AM BTECH GMRS-RPT50 Repeater 1.008R Release New Features and Improvements in 1.008R Release Date: 02/26/25 1. Hand Microphone Full Transmit/Receive Functionality: With firmware 1.008R, the hand microphone is no longer limited to just configuration tasks—it can now be used for both transmitting and receiving, effectively allowing the GMRS-RPT50 to function as a base station in addition to its role as a repeater. This means users can key up and communicate directly through the repeater without needing an external radio, making it more versatile for base station operation in home, emergency, or mobile setups. Whether monitoring local traffic or coordinating with other stations, this feature adds convenience and flexibility to the repeater’s capabilities. 2. Streamlined Menu: The firmware’s menu system has been refined to remove unused, redundant, or rarely accessed items. This decluttering makes it quicker to navigate the settings you actually need, reducing the likelihood of user confusion or misconfiguration. 3. CW ID On/Off: CW ID is the Morse code identifier that can be sent automatically to comply with identification requirements. Firmware 1.008R lets you decide whether to turn this ID feature on or off, giving you the flexibility to manage IDs exactly how you prefer—either automated via CW, or handled manually or by external logic. 4. Adjustable Squelch Level: You can now more precisely set how sensitive the repeater is to incoming signals. This is helpful if you live in an area prone to weak signals or noisy RF environments. By raising or lowering the squelch threshold, you can reduce unwanted static triggers while still allowing legitimate signals to pass. 5. Carrier Squelch RX/TX Mode: Previously, many repeaters required a CTCSS or DCS tone to activate transmit or open the squelch. With 1.008R, you have the option of pure carrier-based operation, ignoring any sub-audible tones on both receive (RX) and transmit (TX). This is especially handy for simple or wide-area repeater setups where tone-based access isn’t required or desired. 6. CTCSS/DCS Transmission with Identifier: Firmware 1.008R introduces a new configuration option that allows the CW ID to be transmitted either with or without the CTCSS/DCS tone used by the repeater. This gives users the flexibility to choose whether the station ID follows the same tone settings as regular transmissions (for systems requiring a uniform tone policy) or if it is sent without a tone, which is the standard practice for identification. This option ensures compatibility with different repeater setups while maintaining compliance with identification requirements. 7. Password Disable Option: For those who prefer seamless operation, the password feature can now be turned off entirely. This option removes the prompt that appears when configuration changes, ideal for shared stations in secure locations where password protection isn’t needed. Quote
