TheTechPianoPlayerKid Posted July 1 Report Share Posted July 1 Hi everyone, I have a USB Hotspot duplex device purchased from hotspotradios.com, and I have this connected to a Raspberry Pi. I have already configured the units, and both are working great! My question is this. I want the ability to have simplex nodes to connect to it so they can talk on this miniature repeater. I am having trouble with this. I have already configured port forwarding on the router by the following: 1. I logged into the admin portal of the router and went to the port forwarding/port triggering setting and selected port forwarding. 2. I created a new custom service, and in the name/description I put "GMRS Raspberry Pi1", for this example. In the internal and external ports, both are set to 4569. For the internal IP address range, I put, for example, 192.168.1.123. I saved changes and restarted the router. Then I did a test by connecting one of my other simplex nodes on a separate WiFi network we have but no success. Am I missing something? Do I need to configure a file that allows connections from other nodes? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
TheTechPianoPlayerKid Posted July 3 Author Report Share Posted July 3 Hi everyone, I got it figured out. You can now request access and when accepted, I will provide the node number in the notes when you receive the "request accepted" email. Quote Link to comment Share on other sites More sharing options...
WRZW864 Posted July 6 Report Share Posted July 6 Please explain how you did this... Quote Link to comment Share on other sites More sharing options...
Raybestos Posted July 7 Report Share Posted July 7 18 hours ago, WRZW864 said: Please explain how you did this... ...or better yet, WHY? Is it to make oneself feel important by tying up as many of the eight (and only eight) channels available for repeater and/or 50W simplex use in as many areas as possible, with the same conversation at the same time? WRZK971 1 Quote Link to comment Share on other sites More sharing options...
WRZK971 Posted July 12 Report Share Posted July 12 On 7/7/2024 at 10:40 AM, RayP said: ...or better yet, WHY? Is it to make oneself feel important by tying up as many of the eight (and only eight) channels available for repeater and/or 50W simplex use in as many areas as possible, with the same conversation at the same time? That's what I took out of it. I know what he's trying to do and how to do it. I wouldn't help him even if it was a good idea. I asked him a direct question when I needed help in may, and he just blew it off. It'a all about him. I doubt he has put in any thought about tying up multiple frequencies. Raybestos 1 Quote Link to comment Share on other sites More sharing options...
