Is it normal for this radio to show the wrong frequency when first turned on? For example, when I first turn it on it says the wrong frequency. Then when I change the channel and go back to the original channel it is correct. This happens regardless of which channel I turn it on in the beginning. Has anyone else seen this kind of behavior or did I just get a defective one. If this is normal I'm just going to get a TR-505 instead.
I've seen similar behavior. It seems to happen for me when I disable dual PTT. Probably a glitch in the software.
Sent from my LG-H918 using Tapatalk
