setting up ty-9000d repeater need help on settings.
Guest Ken Field
Here is what I set for the repeater settings in the radio is it correct??
Setting # Receiver Transmitter Options:   1 5K 5K 5, 6.5, 8.33, etc STEPS 2 T-DTMF T-OFF T-OFF, DTMF, T-2TONE, 5-TONE DTMF 3 2TON-01 2TON-01 2TON 00 – 31 2-TONE 4 5TON-00 5TON-00 5TON—00 – 99 5-TONE 5 DTMF-01 DTMF-01 DTMF -01 – 16 DTMF 6 SPK-C/T SPK-SQ SPK- SQ, CTC, TON, CXT, C/T HEAR CALLER 7 POW-LOW POW-HI POW LOW, MED, HIGH TRANSMITT POWER 8 BAND-25 BAND-25 BAND-25, 20, 12 BANDWIDTH 9 TX-OFF TX-ON TX-OFF, TX-ON TRANSMITTER DISABLE 10 LOCK-OFF LOCK-OFF LOCK-OFF, BU, RL, OF CARRIER LOCKOUT 11 RECEIV XMITT CHANNEL NAMING   12 REV-OFF REV-OFF REV-ON, OFF RX CHANGE TO TX FREQ 13 TALK-OFF TALK-OFF TALK-OFF, ON TALK AROUND 14 COMP-OF COMP-OF COMP-OF, ON VOICE COMPANDER 15 SCR-OF SCR-OF SCR-OF – ON SCRAMBLER 16 D-123 D-123 D-000 TO 999 DTMF SELF ID 17 P-12345 P-12345 P-00000 TO 99999 5-TONE SELF ID 18 BEEP-ON BEEP-ON BEEP – ON – OFF BEEPING KEY TONE 19 TOT-5 TOT-5 TOT-1-30 MIN TIME OUT 20 APO-OFF APO-OFF APO-OFF ,ON AUTO POWER OFF 21 SPD-30 SPD-30 SPD-30, 50,100, 200, 300, 500 TIME FOR SENDING EACH DTMF SIG 22 SQL-OFF SQL-4 BAND-25, 20, 12 SQUELCH 23 SCAN-TO SCAN-TO SCAN -TO, CO, SE SCANNING SEQUENCE 24 LAMP-25 LAMP-25 LAMP 01-31 SCREEN BRIGNTNESS 25 COLOR – 1 COLOR – 1 SCREEN COLOR GREEN RED ORANGE 26 TB-1000 TB-1000 TB-1000, 1750, 2100 1450 PIOLET FREQ HZ 27 DSP-FR DSP-FR DSP-FR, CH, NM FR = HAM RADIO 28 CODE-OFF CODE-OFF CODE-OFF , ON RADIO PASSWORD SETUP 29 BOOK BOOK BOOK, ID-00 TO 127 SET-UP GROUP 30 RESTORE RESTORE RESTORE, FACT, SETUP RETURN TO FACTORY, CLR 18-28
Please let me know. Thanks for the help.
regards  Ken Field KO9H 73's
ken-field@comcast.net
  • 2 months later...
===VFO===
Short press P3 to switch between VFO and Memory channel.
On the mic you can press the VFO button on the upper right.
===CTCSS===
Short press P5 to cycle though various tone, tone squelch, etc...
===repeater offset===
To turn on or off repeater offset push and hold P4
* push and hold down once - offset frequency.  typically this is 1.600 for 1.25 repeaters
* push and hold down again - changes + or - offset shift
===program channel===
Select a VFO frequency
