I have a bunch of RITRON DTX-450 modules I need to program for a GMRS repeater project. It is a one time deal so I intend to cobble up the 3.5 mm programming plug and wire to a Motorola RIB box. The problem is that the documentation is unavailable to determine which of the tip, ring or sleeve are for TX and RX data. I am assuming the sleeve is data ground. The only schematics I can find are for a cable that terminates in an RJ plug for use with RITRON's proprietary RIB, and the data labels are missing. I am using a Motorola RIB, so any help would be appreciated.
I assume the same cable is used for Jobcomm and Patriot radios.
I am in Orlando Area if anyone is willing to loan out their programming kit for a day.
JLeikhim
Thanks
0 answers to this question
