WSGE216 Posted December 11, 2024 Report Posted December 11, 2024 I just bought an inexpensive Baofeng to get myself started, and my FCC GMRS license and I'm looking for a group to help me learn a bit more than me watching endless YouTube videos. For example, after joining RepeaterBook & MyGMRS, I set up the T & R CTCSS frequencies, then tried to do a channel check - I think I successfully sent, but all I heard back was static. Do I need approval to use the repeater? (And sorry for not getting it first!) Or did I set my radio channel incorrectly?
WSDH649 Posted December 11, 2024 Report Posted December 11, 2024 I think you might have it setup correctly. If you are hearing the CW_ID continuous wave (morse code) then you at least have the correct receive frequency set. It is an open repeater so you can use at will. The access request on mygmrs is just a courtesy to the station owner in my case. I will be monitoring when I get home, or on my way home and I will reply if I hear you on. Also, I will check the notifications when new post are made here. Glad you got the UV-5R plus and the Bingfu antenna. If you end up getting your HAM license you are set to go on 2m(144 ish MHz) and 70cm(440 ish MHz)
WSGE216 Posted December 12, 2024 Author Report Posted December 12, 2024 Thanks @WSDH649 - I tried to transmit a couple times at around 7:15 PM - but not sure anyone heard me. My transmit frequency is correct per the the uplink freq on MyGMRS. Maybe I'm not reaching you? I'm about 2 miles east of your repeater in a wooded area and neighborhoods in-between.
WSGE216 Posted December 17, 2024 Author Report Posted December 17, 2024 Hi - has anyone heard any of my transmissions? I've been doing radio checks mostly in the evenings. I picked up a Nagoya 771G and will test it at about 6:00 tonight.
WSEM281 Posted December 18, 2024 Report Posted December 18, 2024 Negative from my location 216, I'm about 3 miles E/SE of the repeater and keep my scanner parked on GMRS, no longer hearing traffic on the repeater from my location. We can try a check-in around 6:00pm occasionally on simplex 17/.600 with a tone of 156.7. Distance and obstructions may hinder our ability to get out but it's worth a shot to determine if we can talk without the repeater, assuming we are within range of each other
WSGE216 Posted December 18, 2024 Author Report Posted December 18, 2024 Thanks 281 - I'm around 2 miles E of it. My input & output tones are right (unless Baofeng messed up how tones are set up on my radio) I'll hope to connect with you at 6:00 on both 17/.600 and 25/.600
WSGE216 Posted December 31, 2024 Author Report Posted December 31, 2024 I updated to a Diamond SRJ77CA antenna and now when I transmit, I get a morse code response! I did it twice & each time I got beeps a few seconds after my transmission.
WSDH649 Posted January 6 Report Posted January 6 Checking in after awhile. I missed some things. But, basically, until I get the antenna raised higher it will be tough to reach the repeater with a handheld outside of the neighborhood. Still aiming for spring on the 46 footer. Maybe late winter if budget permits.
WSEM281 Posted January 25 Report Posted January 25 I have started a Facebook group for those interested in joining. The group name is Stafford County GMRS Radio. I hope you will consider joining me as we build a more connected community through GMRS. Best regards, - WSEM281
neidermeyer Posted Monday at 11:51 AM Report Posted Monday at 11:51 AM On 1/24/2025 at 8:55 PM, WSEM281 said: I have started a Facebook group for those interested in joining. The group name is Stafford County GMRS Radio. I hope you will consider joining me as we build a more connected community through GMRS. Best regards, - WSEM281 I’ve searched for the Facebook page but it doesn’t come up. Is it private?
WSEM281 Posted Monday at 09:02 PM Report Posted Monday at 09:02 PM Apologies, yes the group is set to private but still visible to everyone, however since there aren't any members, there isn't any content. I will provide the link below and hope we can begin sharing information! https://www.facebook.com/groups/3915034312100061/?ref=share&mibextid=NSMWBT
