Chirp Error Code "short read of the block 0x0000"
Hey! I've just gotten my Radioddity DB25-G and I'm trying to connect it to Chirp via my Mac. (Yes, the DB25-G is compatible.) I have the correct port selected. When I download from the radio I get a error message that says, "Error communicating with radio. Short read of the block 0x000" and then the radio reboots.
Clearly something is not right. I use Chirp all the time with my Baofengs without issue.
Any tips from someone who has had this error code before? Thanks!
  On 2/12/2025 at 1:34 PM, ts199982 said:
I get the exact same error when using Chirp, Short read of the block 0x0000. I have tried multiple computers, Windows 10, Windows 11, same result. The Radioddity software was even worse, but can't recall the error. Not sure what to try next?
Expand
What I did was return the unit to Amazon. I talked with their customer service and they sent me a new programming cable that changed nothing. With the second unit, I was able to get the Radioddity software to work... kinda.
I would return the unit if it's not working with either software and see if the replacement works better.
