WSGF881 Posted April 1, 2025 Posted April 1, 2025 Anyone else out there with fat fingers that have difficulty connecting an external antenna using a PL-259 to SMA adapter to their handheld radio? Here is the answer: 3D print a 19mm disk, 5mm thick with 8mm hex hole in the middle. Lightly coat the interior of the hex hole using a Qtip with cyanoacrylate (super glue), slide onto adapter N nut allowing glue to set for 3-4 minutes. Quote
Lscott Posted April 1, 2025 Posted April 1, 2025 11 hours ago, WSGF881 said: Anyone else out there with fat fingers that have difficulty connecting an external antenna using a PL-259 to SMA adapter to their handheld radio? Here is the answer: 3D print a 19mm disk, 5mm thick with 8mm hex hole in the middle. Lightly coat the interior of the hex hole using a Qtip with cyanoacrylate (super glue), slide onto adapter N nut allowing glue to set for 3-4 minutes. I typically go from the radio connector to BNC. Usually you can find an adapter for some weird antenna port type to BNC so I use it as a common interconnect type. I have a lot of RG-58 patch cables. You'll also end up with a collection of adapters after a while too. https://forums.mygmrs.com/gallery/image/427-adapters-connectorsjpeg/?context=new Here is an example of the Icom specific radio port type and the adapter to BNC I got for it to use external antennas. I had to order this special since it's not very common. https://forums.mygmrs.com/gallery/image/500-ic-f3162dt-front-and-back-sidepng/?context=new Quote
WSGF881 Posted April 2, 2025 Author Posted April 2, 2025 Socalgmrs I had not really considered that as I have the coax hanging vertically from the above the radio in a fixed location. However, you make a good point, so version 2 is designed to prevent lateral torques while still allowing the collar to be used as a wrench for the SMA nut. Also has the benefit of no glue and is similar to adapters that I have made for other SMA mobile antennas (i.e. Retevis RHD-771) . Quote
