Hey all I think I have my radio setup correctly but I don’t seem to be able to transmit, I have a tidradio td-h3, I programmed the Thompson station repeater into it and heard a few people but no one could hear me, any advice?
42 minutes ago, SteveGibbs said:
When you attempt to transmit, do you hear the repeater "squelch tail" (signal without modulation) for a few seconds after you release the PTT button?
no i hear nothing when pressing transmit
12 minutes ago, WSDV406 said:
What mode is your TD-H3 in (GMRS, HAM, Unlocked)? Do you have your repeater channel offsets setup properly?
it is gmrs and yes i am sure, if i use the default channels it seems to work but if i use one i program myself it doesnt seem to work for some reason
Interesting. I actually heard somebody on the Gallatin repeater this afternoon expressing that they were having the same issue. Was that you? I can't recall the call sign of the person that was expressing that issue.
I'll say this, I have a couple of h3's and a couple of h8's (and ive programmed several of both for other people), can I have had 1 lemon. It would receive wouldn't transmit, the programming wouldn't stick, and a few other weird issues.
So my first bit of advice to you would be order a new one and see if everything works as it should. If it does, then you simply just had a lemon.
My second bit of advice would be to unlock it. That's the way I use all of my h3 and H8 radios. See if things work right once the restrictions of GMRS mode are gone.
