  2. Zello is shutting down the PC version and older versions on June 25th
  3. What do you mean by "max 5 watts"? You're receiving a signal from unidentified source. You would have no way of knowing its power output without the message you're receiving telling you. I know in amateur radio there are beacons set up that continually emit a morse code (cw) message that tells a call sign, a location, and power level. This is used by others to determine if a band is propagating. But you just get this "sometimes", so it's more likely that someone has equipment that is outputting morse to identify their station. However, if you're really curious, you can record the signal, and use an online morse decoder (or decode it yourself manually) to read what the message is saying. That will probably tell you who owns it. ...- ...- ...- is usually the beginning of a beacon's signal. The "vvv" symbols are easily identifiable as a beacon preamble.
  4. Today
  5. My radio can scan all gmrs frequencies.. some times I get a morse code Ident on channel 6...max 5 watts.... what could it be? " 06 462.6875 2 W 12.5 kHz 5 W
  6. Yes they can easily figure out the tones. Now if it is someone "passing through" then nothing much will come of it. But if it is a local then actions can be taken. There is no guarantee that any actions taken against the offending person will have much effect, but you have to start somewhere before lawyers and/or the FCC gets involved. I leave that to our club's executive board to deal with. So far we haven't had any problems and the couple of times framers/businesses tried to use the repeater, they were told not to do it and they quit.
  7. only one time in 7 years of using GMRS was i ever asked to register, or request t to use a GMRS repeater. It was in Auburn, Calif in 2020. As i was travling through on I80 Ch 18 broke loose with someone asking for a radio check. This Ch happend to be programed with the same and PL codes of a repeater here in the desert After giving the other party a radio check and talking for 20'ish minutes. The owner just popped in introduced his call sign told me it was his repeater and asked me to submit a request here to use. It was no big deal, the guy was nice about everything. I never did fill out a request to use cause i havent been through that area since.. Frankly, i can't even keep up with the ones have requested access too.
  8. Keep changing it and they'll likely get tired of pursuing it. Most have a hard time programming the tone in with explicit instructions.
  9. I've often wondered about the practical reality of "we don't allow...to use our GMRS repeater" when all they need is the correct tone. Notwithstanding the reality that many can't figure out the tone, for those that can and do, then what? If they are locals and are doing it on a regular basis, as opposed to some unknown random person or group passing thru the area, it isn't difficult to figure out who they are. Clearly that would be the first step in any sort of enforcement action. But what a PITA. Then what? Report it to FCC and cross your fingers, I guess... IDK, the whole thing is based on the honor system and as we see, or rather hear, with some degree of regularity, some folks just don't care about rules.
  10. It's all the wicked Wick's fault.
  11. Lscott
    Misc. Radio Gear
  12. I paid close to $100 for mine at the Hamvention. Who knows, might have been due to the tariff crap then. R and L Electronics, which seemed to have the best price, was out of stock when I looked a while back. Plus they didn't have a booth at the Hamvention, which I though was sort of strange since they are one of the better known Ham gear vendors. This is a link to a photo I just added to my album with the testing results and a photo of the antenna in it's protective sleeve. Note the antenna is clearly marked as a NR240CA. I've seen the NR240C being sold. Not sure if they are the same or not. https://forums.mygmrs.com/gallery/image/613-nr240ca-roof-rack-mount-swr-and-photojpg/?context=new
  13. That's a good price. And it is only 10-20 dollars more than the 2x4SR. The Antenna Farm has the best price I found for the 2x4SR at $62 and DX Engineering was $70
  14. Thanks. I'm going to order it. I don't have a true "no ground plane" situation, just a hood-fender mount, so it's an incomplete ground plane. And I've found that the CA2X4SR has too high of an SWR in the 462-467 range. It's even pretty high in the upper 420-450 range, on this vehicle. It really does like a good ground plane.
  15. The antenna is a 5/8 wave design, and really does need some kind of ground plane to work. For whatever reason it seems to work rather well on my roof rack mount. I suspect there is some coupling, capacitive, through the mounting strap to the rail plus the metal roof on the vehical. A close up photo of what the mount looks like with an antenna installed on it. Note I use the UHF type mounts whereas most people like the NMO type. You can clearly see the electrical tape on the base of my old antenna since the fold over spring is worn out. I've been driving around like this for years. The mount is on the driver's side so I can reach it and unscrew the antenna when necessary. https://forums.mygmrs.com/gallery/image/473-close-up-of-mobile-mount/?context=new
  16. https://www2.randl.com/index.php?main_page=product_info&cPath=2_1240&products_id=76310 I got mine at the Hamvention last May from a vendor. I forget who it was, but the source in the above link has them.
  17. The Diamond antenna is a bit different. There is a locking collar you have to unscrew to lift up the antenna to fold over. No spring to wear out like on the Comet design. Another reason to go with the Diamond antenna for those interested in it.
  18. I hear the same here in mid Missouri all of the time. And some are even using GMRS mobile radios in their farm trucks. And like you, I never hear them use any call signs. That is part of the reason why we don't allow businesses and farms to use our GMRS repeater.
  19. I've been looking for days for a source for the NR240CA. I have a CA2X4SR-NMO but it's not quite right for the ground plane I have under it. Instead, I'm using a Laird TE B4505CN for GMRS, and a 2m/70cm no ground plane antenna when working in amateur bands. But it's got a higher SWR (>2.4:1) at 462-468. One antenna that is a no-ground-plane antenna that covers the range advertised for the NR240CA would be ideal. Nobody's got it advertised for sale, that I can find.
  20. This is very true. Some antenna designs are worse than others about the SWR changing in rainy weather. I deal with this all the time with my 6m-20m cobweb antenna. The cobweb design is more susceptible to SWR changes during rain than other antenna designs. The SWR changes are normally within what the radio's builtin tuner can handle. I would love to run a longer antenna such as the 2x4SR on my Ford Escape full time but adding 38-40 inches to the top is a no go since I park the Escape in the garage with 7ft tall doors. I know they fold. but as you mentioned, the fold over will wear out if used all of the time. And I am also afraid that I will forget to fold the antenna and mess it or the vehicle up. The Comet SBB1 just barely clears the garage door as is.
  21. Good idea for anybody who is going to routinely use this antenna mounted up high. I picked one up at the Hamvention last May for mine for future use. I would install it if I planed on using the antenna at some point. Right now I have my old CA-2x4MB on the ride. That monster is about 60 inches tall. https://forums.mygmrs.com/gallery/image/471-mobile-mount-with-antenna-rear-view/?context=new The match on it is something else. This was done when I had it on my old Jeep. It looked better than the newer CA-2x4SR. The one on the ride the fold over string is shot, that's the black electrical tape you see, the antenna is at least 20 years old. I do have a new one still in the green plastic sleeve, never been outside of the house. I purchased both at the same time. https://forums.mygmrs.com/gallery/image/223-ca-2x4mb-jeep/?context=new https://forums.mygmrs.com/gallery/image/282-ca-2x4mb-scansjpg/?context=new I've been looking around for a possible replacement for it. After testing the CA-2x4SR and N240CA, on my roof rack mount, either one might be a good replacement, and they are only 40 inches tall. I might go for the NR240CA, yeah it's more expensive, but the SWR match looks a bit better over the ranges I'm interested in. One thing people don't talk about here, or elsewhere for that matter, what the match looks like in crummy weather, like moderate to heavy rain or fog. It's going to get worse to some degree. If you start out with a really low SWR it likely won't deteriorate nearly as bad in less than ideal weather. Modern radios are designed to tolerate SWR's up to 2:1 at full power. After that the radios, with SWR protection circuits, will start to fold back power to protect the output power stage.
  22. I picked up a no-name one at a local swap a long while back just for fun, it was really cheap. Tested it and I wasn't impressed with this sample. Likely better ones out there. https://forums.mygmrs.com/gallery/image/428-stealth-dual-band-with-swr-scanjpg/?context=new
  23. I think it just comes out the other way. But full disclosure — I am a member of RR. What I really refer to is the people on there who see a forum post marked HALP MEH! and they chime in with "do your own research" instead of just helping a new amateur. It's like with Linux forums... mostly unhelpful jerks who pretend that they were born with what they know so others shouldn't ask for help if they weren't
  24. Sometimes you can mess something that works well by pursuing perfection. "Good enough" is a valid concept.
  25. WSHZ762
    WSHZ762
