WRHV695
Everything posted by WRHV695
  1. My setup is very similar to Josh's up above using the MX275 Connected to battery positive in the aux switch harness under the Jeep gladiator's glove box area. Ground is to a grounding post in the passenger kick panel. I am using a similar cowl mount for the 3db and 6db antenna (I swap them out depending on application). I get a slight whine when ignition is in accessory or run. It does not appear to be variable with RPM. Just a slight whine. Antenna is not grounded I have tried ferrite coils, etc with no luck. For you jeep guys, what was the ultimate solution?
