I'm going to strongly encourage you to check out @OffRoaderX's YouTube channel (NotARubicon). From the basics of GMRS operation to real-world repeater information, he explains it in such a way that anyone can understand.
The bottom line is that you *can* connect a pair of KG-1000G radios to make a repeater, but from what I read the duty cycle (Tx time vs. cool-down time) is going to be relatively low. If you want to set up a repeater, I second the recommendation to purchase a dedicated repeater. You can purchase a Motorola GR-1225 setup -- with duplexer -- programmed and tuned to your chosen frequency pair for ~$700.
That's less than you'd have in the pair of KG-1000Gs, and you'd still need a duplexer and power supply for the Wouxun setup.
I've recently put a Motorola XPR8300 repeater on the air, with a Tram 1486 antenna about 30 feet above ground level. The usable range of this setup with the topography in my area is ~20 miles with a mobile radio (25-50W), and 10-15 with a handheld (5ishW).
