The amount of acceptable cable attenuation depends greatly on your antenna gain and its location. If you have an efficient antenna mounted high in the air, the antenna can make up for a good amount of cable attenuation. Conversely, if you have an inefficient antenna or the antenna is mounted poorly, you will need to almost eliminate cable attenuation in order to achieve any significant transmission distance.
For short cable runs, less than 10 meters, almost any conventional cable can be used without major impact on the signal strength. For long runs, as would be expected for a base station, low loss cable is far more important than the radio output power.
