ShaneF
ShaneF's Achievements
  1. Thanks it worked Both radios are in channel mode and working
  2. Just for my own edification, perhaps you can explain why it didnt work before since I thought channel 20 was the same as frequency 462.675. And if they are different why i could talk one way but not the other. Again thank you
  3. Thank you, Thank you Thank you it worked. I feel like an idiot but now I am good!!!!!!!!!!!!!!!!!!
  4. I recently bought 2 Baofeng UV-5G GMRS radios to use on an upcoming cruise. I also have two Midland 1000 V4. The Midland is set to channel 20. which is equivalent to 462.6750 on the UV-5G. OK, now the two Midland radios will communicate with each other and the two Midland radios will communicate with the UV – 5G. BUT the UV-5G radios will not communicate with each other and will not communicate with the Midland. Can someone assist me in figuring out why this is happening so I can fix it. I can speak from the Midland to the other Midland and the 2 UV-5G but when i speak in the 2 UB-5G nothing happens. Any ifeas
  5. I will try that but the issues is i can talk FROM the midlands but not from the UV-5g
