Reclusiarch
Everything posted by Reclusiarch
  1. @WRXB215 Good evening, I was unable to connect to the Wouxun radio with either CHIRP or the Wouxun software (not sure why). Fortunately the radio was programmed with all of the correct frequencies and power settings already, so once I reprogrammed the Baofeng radios they worked just fine.
  2. Wow, thanks for the quick response! If you are the same person whose videos I have seen on YouTube (since your forum photo is familiar) then THANKS, I have learned a ton from watching your channel! Okay, back on topic: Yes, I am using the same cable. I ensured the correct COM port (5 for some reason) was is in use however, I did notice one thing the 2way site mentioned: the Wouxun software **must** be run in compatibility mode in order to function correctly; odd, yes? I'll try your suggestions of cycling through the ports, running as Admin, and then follow up with a nice cup of hot coffee while it re-installs. Thanks again for the response!
  3. Hi all, I am a newcomer to myGMRS.com and its forums, but I have a question, and I am hoping somebody might be able to help me. As my post title implies I am trying to get into the channel programming (and tone codes, etcetera) for my Wouxun KG-905G GMRS 5watt radio. I purchased two Baofeng BF-888S radios and wanted to have all three radios work on the same channels and frequencies. I used the CHIRP software to backup the original programming of the two Baofeng radios (thanks YouTube DIY videos, lol), and then manually entered in the correct frequencies for GMRS channels 1-7, FRS channels 8-14, and GMRS channels 15-16; along with resetting the transmission power levels to the correct 5w/0.5w/5w settings per the FCC rules. When I tried to use CHRIP on the Wouxun KG-905G however, it was not functional. It seems all of the listed Wouxun radios are 'experimental' and the 905G is not listed; nor would CHIRP communicate with the radio using a different radio type/name (1000 series, etcetera). I then downloaded KG-905G software (from twowayradios.com?), set the correct COM port, but still could not make a successful communication with the Wouxun radio. While I do have all three radios communicating as I wanted, my concern is the lack of ability to "get into" the programming of the Wouxun radio. Any tips or advice would be greatly appreciated! Thanks in advance.
  4. Hi all, I'm new to the site (and the forum) but am impressed by the wealth of information I have seen so far! I picked up my GMRS license last year when my family and I took a vacation in the eastern edge of TN by the Appalachian range. While we never got stuck/lost and "needed" it, I was happy to have it as a backup. Now I'm getting interested in learning a bit more about GMRS, and figured this was a good place to start!
