DMRUSSELL
Everything posted by DMRUSSELL
  1. Good morning, I am very aware of RT Systems software and Tidradio Software, use them daily so I get how they work. As for Chirp, I have programmed 100's of radios and never experienced this so I don't believe chirp has anything to do with it. I have spent countless hours dealing with Tidradio about this issue and it's still a mystery. so my next step is to get a frequency reader and see if the radios are putting anything OUT. I appreciate your opinion, but I do not believe Chirp is this issue as i have 3 other Tidradio H8s programmed EXACTLY like the 2 that don't work, and they are flawlessly perfect radios. Thank you and have a great weekend.
  2. I switched to all GMRS, HAM, UNLOCK and the firmware stays the same. the new radio I have is on 230911 and the bad ones I updated are on 230923 and those don't change when switching between GMRS, HAM, UNLOCK. I agree with you about Odmaster i absolutely cant get that to work at all. I did download from Tidradio, their software and its very easy to use. someting in that 230923 firmware is blocking something. I am NOT gonna update the new radio from 230911 to 230923 for fear it will stop working also.
  3. Ya i have even used other cables, to different software's, manually entered everything, set and reset, the only thing i can think is try to figure out a completely factory reset somehow and go back to the old firmware. crazy what's going on here. baffling in fact.
  4. No, I didn't send the bad ones back. Tidradio and i emailed back n forth for over a month. 55 troubleshooting emails to be exact. finally they said " Keep your radio's and we are sending you a new one" So they did and i loaded it and it works perfectly. so now i have 1 good radio and 2 that wont work on GMRS repeaters/with tones. will not transmit.
  5. Hello Guys, so yes they (2) radios will not transmit with tones, they receive just fine and always work on simplex. I finally got a replacement radio from Tidradio and programmed it several different ways, Chirp, Tidradio software, GMRS, and unlocked. THAT new radio works flawlessly. So i copied the programming and re programmed the bad radios. NOPE, they still dont transmit. comparing menu's i found the new radio is on the old version of firmware 230911 and the bad radios i did upgrade to the new version 230923. so I'm wondering if somehow i can take those back to the 230911 firmware ?? So its got to be something in the settings that's blocking TX. comparing radios, ALL setting are identical except the firmware version. any ideas would be much appreciated.
  6. Hello all, So i have 2 Tidradio H8's programmed with chirp and Tidradio software. My issue is on Simplex transmitting works just fine but when i put tones in TX or RX or even both, it will not TX, i can RX just fine. I have several radios, Tidradio, Baofeng, Kenwwood, Yeasu, (several diff models of each) and ALL are programmed identical to each other. All work flawlessly except the Tidradios. I have a LONG list of troubleshooting i have done : Updated firmware. Reset to OEM. Checked and rechecked all freq's and tones. Mic gain up in settings. Hand input all freq's and tones. Changed batteries, antennas, un-locked, set back to GMRS, set to Ham, erased and re programmed. Changed channel locations in the radios several different times. Left the house and used in outdoor setting with zero obstructions. Repeaters are 1 mile to 20 miles away and ALL other radios hit every on fine. I have been emailing with Tidradio support and that's been a night mare. troubleshooting for weeks now with them. Ive probably missed listing what i have done but if you have any advice, I'd be greatful. P.S. they will both access Ham repeaters just fine. and again, simplex everything works fine. advice or questions email me (Dave): bigtime24fam@gmail.com
