WSAZ300
Everything posted by WSAZ300
  1. I can Tx/Rx to one local repeater, but not another (I'm well within range/LOS). I can receive well, but cannot transmit. See below repeater info from myGMRS. I've tried all of the given input tones. I don't know if this info helps, but I was able to hear only one side of a conversation today. I am using a preprogrammed repeater channel on a Radioddity DB-25. I appreciate any thought into this. LOCAL TALK TONE 103.5, 141.3 TRAVEL TONE ENCODE SIDE ONLY CARRIER ON RX. REPEATER IS LINKED TO OUR DIAMOND PT, SHAWBUTE, GREENS PEAK AND WRAP405 TOWERS MTN 600 24/7. USE DCS CODE 265N ON THE ENCODE SIDE OF YOUR RADIO ONLY FOR LINK ACCESS, CARRIER ON YOUR DECODE SIDE. THIS REPEATER IS CONNECTED TO THE SWCRS NETWORK VIA DIAMOND PT ON WEDNESDAYS 16:00 HRS-18:00 HRS, SUNDAYS FROM 15:30 HRS TO 18:00 HRS FOR REGIONAL AND NATIONAL NET USE. FOR MORE INFORMATION VISIT SWCRS.ORG.
  2. They may have, I'll have to scan for a different tone. It's the same per the repeater map but maybe not updated. Thank you! I hadn't thought of that.
  3. I've been communicating with folks on a local repeater, but when I switch to the appropriate channels/tone to another local repeater, I can receive but not transmit. I was able to transmit to the repeater before. This does come after the repeater is down, but I have heard other folks transmitting and receiving since it came back up. I tried a different radio just in case, with the same result. Any thoughts? Radio info: Radioddity GM30.
