Hockeydude
Hockeydude's Achievements
  1. I have confirmed, when transmitting that it is changing from 462.xxx to 467.xxx with the offset being at 0.00. I took that radio out to lunch and someone did respond back they could hear me, so I am thinking that it could me my home area and his work location causing interference for transmitting since we can hear others on the repeater channels.
  2. Good morning, We have tried three sets of Baofeng radios and setting them up the same way with either CHIRP or directly on the radio and it's always the same result.
  3. I used CHIRP to program the radios an in the software the offset is set to +5.0. After programming, when going through the radio menu, it shows the offset as 0.00.
  4. I actually started with the repeater owner and sent the setting I have in the radio and he thought it might be the offset is set to 0.00, and I am able to change it to 5.00. However, after powering off the radio it's not saving the setting. If we were to try different radio's, is there one that you would recommend? Thanks
  5. I am within 2-3 miles from the repeater and my friend was about 2-3 miles away as well, just in the direction.
  6. @WRXP381We are, we can hear others on the repeater without issue. We are using the antenna that came with the unit. We did try simplex and that worked without issue
  7. @OffRoaderX The person on the other end of the radio is only hearing static and not my voice for the entire time of the conversation. I am nearing nothing when talking, but i do hear the tail after releasing the PTT.
  8. Good evening, A friend and I recently purchased the Baofeng UV 5G Plus and used CHIRP software to program some of our local repeater. The issue we are having is when transmitting it's nothing but static. However, when just listening we can hear others without issue. We have programmed the appropriate Tx and Rx codes and I can see when transmitting the frequency will jump up 5 (example, repeater is on 462 and when transmitting it jumps to 467). Anybody have suggestion on the cause or a potential solution? This is happening on all repeaters we have programmed in the radios. Thanks
