mydog8em
mydog8em's Achievements
  1. I also have this repeater and by timer, i can not get it to ID to save my life. I've followed all instructions to the T and it will still only ID on TOT but not on timer. RepeaterID makes a general purpose CWID transmitter that simply hooks to the Kenwood port of an HT and the other into the ID device. from there it xmits the CWID from the HT that is progg'd to the repeater. it works 100% and i dont worry about this repeater ID'ing. I dont work for, or are affiliated with RepeaterID, just wanna help, i know the frustration.
  2. The repeater came with a hand mic, it works on both radios. not a keypad but just a standard PTT with a green LED. I also have the 1225 non LS ver. 4.0 which does the same. I'm kinda scared to take it apart, but soon as i can or do I'll check the model #.
  3. Hello, I have this setup currently programmed for 467/462.5500 PL 127.3. Works great but it turns out i need to change the frequencies. I bought a single M1225LS to play with and it reads/programs fine. However, I put either one of the repeater radios on it and they both say the radio is not active, check cables etc. etc. Does something need to be done to activate them for programming? Thank you for any info provided. I'm using the LS/CPS v3.0 if that helps.
  4. Just got one NOB on ebay. receives and seems to work great but only outputs 3-4W no matter the TXP setting. Using an AC power meter, it only pulls 25W on the AC mains when keyed. Updated its firmware from 0.0.1.2 to 0.0.1.3, no change except for a cpl. menu options. I also have 2x RA87s in a repeater config and at 40W, they each pull 165W from the AC and xmit 40-42W, all using the same Tram antenna about 100' high. I have word out to Radioddity but haven't heard back yet. Thank you for any info you can provide. ~Mike302
